Prikazi cijelu temu 27.09.2013 13:06
biromega Van mreze
Registrovan od:10.12.2010
Lokacija:Breza
sync_clients.xml
<?xml version="1.0" encoding="UTF-8"?>
<!-- Synchronization of client databases between fiscal device and PC -->
<!-- Attributes: -->
<!-- Type = "1" - Download item DB from device to PC file; "2" - Update DB from PC to device (add or replace rows); "3" - Program all items from PC to device. -->
<!-- File - Name of item database file. This attribute is ignored for Type="3". The default file is defined in SyncClientDB registry value. -->
<TremolFpServer Description="Synchronize Client DB" File="c:\temp\clients.txt" Type="1" Command="SyncClients"/>
Clients.txt
Preuzimanja:249
Velicina datoteke:288 Bajt
