Prikazi cijelu temu 13.04.2015 22:18
Lokacija:Ohrid Makedonija
Predmet:Re: Kopiranje iz baze u bazu
Eve i jas imam nesto takvo jas gi koristam ovie funkcii
  1. Public Function PrevzemiPodatoci() As Boolean
  2.
  3.  '-------------------------------------------------------------------------------------------------
  4.  'Konekcija na bazata za prenos
  5.
  6.   Set cnPren = New ADODB.Connection
  7.       cnPren.ConnectionString = "PROVIDER=MSDataShape;Data PROVIDER=Microsoft.Jet.OLEDB.4.0;Data Source=C:\KASA\TEMP.mdb" '& App.path & "\TEMP.mdb" & ";"
  8.      cnPren.Open
  9.
  10.     If cnPren.State = adStateOpen Then
  11.        frmLogin.labInfo.Visible = True
  12.        For i = 1 To 12
  13.          Select Case i
  14.                 Case 1
  15.                   If AzurirajTabeli("ID_Magacin", "tblMagacini") = True Then frmLogin.labInfo.Caption = "> AZURIRAM MAGACINI "
  16.                 Case 2
  17.                   If AzurirajTabeli("KasaID", "tblKasi") = True Then frmLogin.labInfo.Caption = "> AZURIRAM KASI "
  18.                 Case 3
  19.                   If AzurirajTabeli("ID_Vraboten", "tblVraboteni") = True Then frmLogin.labInfo.Caption = "> AZURIRAM VRABOTENI "
  20.                 Case 4
  21.                   If AzurirajTabeli("ID_Grupa_Artikal", "tblGrupa_Artikli") = True Then frmLogin.labInfo.Caption = "> AZURIRAM GRUPI NA ARTIKLI "
  22.                 Case 5
  23.                   If AzurirajTabeli("ID_Grupa_Komitent", "tblGrupi_Komitenti") = True Then frmLogin.labInfo.Caption = "> AZURIRAM GRUPI NA KOMITENTI "
  24.                 Case 6
  25.                   If AzurirajTabeli("ID_Tip_Trosak", "tblTip_Trosoci") = True Then frmLogin.labInfo.Caption = "> AZURIRAM TIPONI TROSOCI "
  26.                 Case 7
  27.                   If AzurirajTabeli("ID_Vid_Dokument", "tblDokumenti") = True Then frmLogin.labInfo.Caption = "> AZURIRAM TIPOVI DOKUMENTI "
  28.                 Case 8
  29.                   If AzurirajTabeli("ID_Artikal", "tblArtikli") = True Then frmLogin.labInfo.Caption = "> AZURIRAM ARTIKLI "
  30.                 Case 9
  31.                   If AzurirajTabeli("ID_Komitent", "tblKomitenti") = True Then frmLogin.labInfo.Caption = "> AZURIRAM KOMITENTI "
  32.                 Case 10
  33.                   If AzurirajTabeli("Tarifa", "tblTarifi") = True Then frmLogin.labInfo.Caption = "> TARIFI "
  34.                 Case 11
  35.                   If AzurirajTabeli("ID_Valuta_Kurs", "tblValuti_Kurs") = True Then frmLogin.labInfo.Caption = "> AZURIRAM KURSNI LISTI "
  36.                 Case 12
  37.                   If AzurirajTabeli("ID_Popust", "tblPopusti") = True Then frmLogin.labInfo.Caption = "> AZURIRAM POPUSTI "
  38.          End Select
  39.              DoEvents
  40.        Next
  41.
  42.       frmLogin.labInfo.Caption = "> AZURIRAJNETO ZAVRSI "
  43.       frmLogin.labInfo.Visible = False
  44.       frmLogin.cmdPrenosVoUSB.Visible = False
  45.       frmLogin.cmdPrezemiOdUSB.Visible = False
  46.       frmLogin.txtSifra = ""
  47.       cnPren.Close
  48.     End If
  49.
  50. End Function
  51.
  52. Private Function AzurirajTabeli(ID_Pole As String, Tabela As String) As Boolean
  53.      On Error GoTo ErrAzuriraj:
  54.      Dim rsServer As ADODB.Recordset         ' Tabela vo kasa
  55.     Dim rsPren As ADODB.Recordset           ' Tabela za pezemajne
  56.     Dim rsAzuriraj As ADODB.Recordset       ' Tabela za pezemajne
  57.
  58.      AzurirajTabeli = False
  59.
  60.     Set rsPren = New ADODB.Recordset
  61.         rsPren.Open "SELECT * FROM " & Tabela, cnPren, adOpenKeyset, adLockOptimistic
  62.
  63.     Set rsServer = New ADODB.Recordset
  64.         rsServer.Open "SELECT * FROM " & Tabela, cn, adOpenStatic, adLockOptimistic
  65.
  66.
  67.     If rsPren.RecordCount > 0 Then
  68.        rsPren.MoveFirst
  69.        Do While Not rsPren.EOF
  70.
  71.            If DLookup(ID_Pole, Tabela, ID_Pole & "=" & rsPren.Fields(ID_Pole)) <> "" Then
  72.                '==============================================================================
  73.               ' Se azurira postoeckiot artikal
  74.               Set rsAzuriraj = New ADODB.Recordset
  75.                    rsAzuriraj.Open "SELECT * FROM " & Tabela & " WHERE " & ID_Pole & "=" & rsPren.Fields(ID_Pole), cn, adOpenStatic, adLockOptimistic
  76.                    rsAzuriraj.MoveFirst
  77.                    For i = 1 To (rsPren.Fields.Count - 1)
  78.                        If rsPren.Fields(i).Value = "" Then
  79.                        Else
  80.                           rsAzuriraj.Fields(rsPren.Fields(i).Name) = rsPren.Fields(i)
  81.                           frmLogin.labInfo.Caption = "> AZURIRAM - " & rsPren.Fields(i)
  82.                           DoEvents
  83.                        End If
  84.                    Next
  85.                    rsAzuriraj.Update
  86.                    rsAzuriraj.Close
  87.                 '================================================================================
  88.           Else
  89.                 '================================================================================
  90.                ' Se dodava nov artikal ako ne postoi
  91.                   rsServer.AddNew
  92.                     For i = 0 To (rsPren.Fields.Count - 1)
  93.                       If rsPren.Fields(i).Value = "" Then
  94.                       Else
  95.                          rsServer.Fields(rsPren.Fields(i).Name) = rsPren.Fields(i)
  96.                          frmLogin.labInfo.Caption = "> DODAVAM - " & rsPren.Fields(i)
  97.                          DoEvents
  98.                       End If
  99.                      Next
  100.                    rsServer.Update
  101.                  '=================================================================================
  102.          End If
  103.            rsPren.MoveNext
  104.        Loop
  105.     End If
  106.    AzurirajTabeli = True
  107.
  108. ErrAzuriraj:
  109.      If Err <> 0 Then AzurirajTabeli = False
  110.
  111. End Function
