Prikazi cijelu temu 03.11.2010 09:21
miro35 Van mreze
Registrovan od:05.01.2009
Evo i code koji pravi ovaj xml uspio sam ga napravit:
  1. Dim RS2
  2. Dim Db As Database
  3. Set Tekst = New Stream
  4. Tekst.Open
  5. Tekst.Position = 0
  6. Tekst.Charset = "UTF-8"
  7. Tekst.WriteText "<?xml version=""1.0"" encoding=""UTF-8""?>" & vbCrLf
  8. Tekst.WriteText "<TremolFpServer Command=""Receipt"" Description=""*** RA UN ***"">" & vbCrLf
  9.
  10. Set Db = CurrentDb()
  11. Set RS2 = Db.OpenRecordset("SELECT * FROM qryIZLAZMP", dbOpenDynaset)
  12.     Do While Not RS2.EOF
  13. 'Tekst.WriteText "<?xml version=""1.0"" encoding=""UTF-8""?>" & vbCrLf
  14. 'Tekst = "<" & "Item" & "Description" & "=" & RS2!ArtNaz & "/>" & vbCrLf
  15.  Tekst.WriteText "<" & "Item Description" & "=" & """" & RS2!ArtNaz & """" & " " & "Quantity" & "=" & """" & RS2!KOLICINA & """" & " " & "Price" & "=" & """" & RS2!PRODCIJ & """" & " " & "VatInfo=""1"" " & "Department=""4"" " & "UnitName" & "=" & """" & RS2!SIFJED & """" & " " & "/>" & vbCrLf
  16. 'Tekst.WriteText "<" & "Item" & ">" & "Description" & "=" & RS2!ArtNaz & "/>" & vbCrLf
  17. 'Tekst.WriteText "<" & "Item" & ">" & "Description" & "=" & RS2!ArtNaz1 & "/>" & vbCrLf
  18. RS2.MoveNext
  19.
  20. 'Tekst.WriteText "<Payment Type=""Gotovina"" Amount=""100.95""/>" & vbCrLf
  21. 'Tekst.WriteText "<AdditionalLine Message=""Linija sa proizvoljnim tekstom 1""/>" & vbCrLf
  22. 'Tekst.WriteText "<AdditionalLine Message=""Linija sa proizvoljnim tekstom 2""/>" & vbCrLf
  23. 'Tekst.WriteText "</Item Description>" & vbCrLf
  24.
  25.
  26.     Loop
  27.
  28.       RS2.Close
  29.       Tekst.WriteText "<Payment Type=""Virman"" Amount=""1""/>" & vbCrLf
  30.       Tekst.WriteText "<Payment Type=""Gotovina"" " & "Amount" & "=" & """" & DSum("[PRODCIJUK]", "QryIZLAZMP") & """" & " " & "/>" & vbCrLf
  31.       Tekst.WriteText "<AdditionalLine Message=""Hvala na posjeti""/>" & vbCrLf
  32.    Tekst.WriteText "</" & "TremolFpServer" & ">" & vbCrLf
  33.       'Tekst.WriteText "<TremolFpServer>" & vbCrLf
  34.
  35.
  36.     Set Db = Nothing
  37. Tekst.SaveToFile "C:\Prodaja\Miro.xml", adSaveCreateOverWrite
  38.  Tekst.Close
Miro
Ovaj post je ureden 1 puta. Posljednja izmjena 03.11.2010 09:23 od strane miro35.
