Prikazi cijelu temu 11.04.2019 14:27
xl_kid Van mreze
Registrovan od:11.11.2008
Predmet:Re: Combobox as you type
Private Sub Narudzbe_Load(sender As Object, e As EventArgs) Handles MyBase.Load
Dim strconn As String = "Data Source=10.10.60.83;Initial Catalog=INIT_DB;User ID=***;password=***"
Dim conn As New SqlConnection(strconn)
Dim command As New SqlCommand("SELECT * FROM Kupci")
command.Connection = conn
Dim adapter As New SqlDataAdapter(command)
Dim table As New DataTable()
adapter.Fill(table)
ListBox1.DataSource = table
ListBox1.DisplayMember = "Naziv"
ListBox1.ValueMember = "ID"
ListBox1.SelectedItems.Clear()
If TextBox1.Text <> "" Then
Dim count As Integer = (ListBox1.Items.Count - 1)
Dim words As String
For a = 0 To count
words = ListBox1.Items.Item(a)
If words.ToLower.StartsWith(TextBox1.Text.ToLower) Then
ListBox1.SelectedItems.Add(ListBox1.Items.Item(a))
End If
Next
End If
End Sub
Private Sub TextBox1_TextChanged(sender As Object, e As EventArgs) Handles TextBox1.TextChanged
ListBox1.DataSource.DefaultView.RowFilter = "[Naziv] like '%" & TextBox1.Text.Trim() & "%'"
End Sub
ovo radi i dobijem traženu pretragu. Problem mi je sledeći. Kako da prebacim fokus na listu?
ili drugi primer koji je ono želim da postignem
Dim AutoComp As New AutoCompleteStringCollection()
Dim dsSerch As New DataSet
Dim ConStr As String = "Data Source=10.10.60.83;Initial Catalog=INIT_DB;User ID=***;password=***"
Dim sqlCon As New SqlClient.SqlConnection(ConStr)
sqlCon.Open()
Dim Str As String = "Select Naziv FROM Kupci"
Dim SqlCom As New SqlClient.SqlCommand(Str, sqlCon)
Dim sqlAdap As New SqlClient.SqlDataAdapter(SqlCom)
sqlAdap.Fill(dsSerch)
For i As Integer = 0 To dsSerch.Tables(0).Rows.Count - 1
AutoComp.Add(dsSerch.Tables(0).Rows(i)(0).ToString())
Next
TextBox1.AutoCompleteMode = AutoCompleteMode.Suggest
TextBox1.AutoCompleteSource = AutoCompleteSource.CustomSource
TextBox1.AutoCompleteCustomSource = AutoComp
End Sub
kao reziltat dobijam samo prve karaktere ali ne i deo reči. recimo za ST dobijem STRUMICA ali ne i AUSTRIA. Da li ima neko rešenja da mi TextBox1.AutoCompleteCustomSource bude rezultat kao i za listbox
