Prikazi cijelu temu 11.10.2020 12:13
Predmet:Imena i osobine polja u tabeli-fetch_fields
  1. <?php
  2. $con = mysqli_connect("localhost","korisnicko_ime","sifra","ime_baze");
  3. if (mysqli_connect_errno())
  4. {
  5.   echo "Nije uspjela konekcija" . mysqli_connect_error();
  6.   exit();
  7. }
  8. $sql = "SELECT *  FROM ime_tabele";
  9.
  10. if ($result = mysqli_query($con , $sql))
  11. {
  12. $fieldinfo = mysqli_fetch_fields($result);
  13. $i=TRUE;
  14.         foreach ($fieldinfo as $val)
  15.         {
  16.                 if ($i==TRUE)
  17.                 {
  18.                 echo "Tabela:". $val->table . "<br>";
  19.                 echo "=========================<br>";
  20.                 $i=FALSE;
  21.                 }
  22.     echo "Ime polja:". $val->name . "<br>";
  23.     echo "Duzina:$val->max_length  ";
  24.     echo "Tip polja:$val->type   ";
  25.     echo "Flag:$val->flags <br>";
  26.     echo "------------------------------------------<br>";
  27.         }
  28. mysqli_free_result($result);
  29. }
  30. else
  31. {
  32. echo "Greška u Query-u";
  33. }
  34. mysqli_close($con);
  35. ?>
